does any one no if can use pci Graphics Card
It appears to be a PCIe board, what isn't working about it?
Please use proper sentences, things make sense.
Right, you want to put a PCI card in your motherboard because your PCIe one isn't working. What was I saying about things making sense...
It should, check your BIOS to see if you can choose the graphics output choice.
Have you tried your 8800GTS in another board?
Any PCI card should work in the PCI slots on the motherboard.
What problem are you having with the 8800GTS in there? Pretty unlikley to get 4 duff cards in a row.
What PSU are you using and are you plugging in the power supply to the 8800GTS?
I assume you have the 8800GTS in the top PCI-E slot?
Are you sure it's the grahics card?
Have you tested the motherboard? No beeps usually mean the motherboard is frazzled and the vital circuits aren't getting power.
As MeatLoaf said, you may get 2 duff cards in a row, but 4... that'd have to be pretty impossible.
yer plug it in to pci-e slot use corsair 620 w power supply motherboard asus blitz formula
all the lights on the motherboard light up plus if take the memory out a get loads beeb and the light at the bottom keep flashing red so dont think its the motherboard
Looks like your keyboards malfunctioning too mate ;)
Id try to contribute something usefull, but really can't decrypt the mess of letters.
My.
Monitor work ok?
Cables all connected properly? (It's surprisingly easy for a VGA cable to come loose).
4/8 pin power plugged into the motherboard?
a try me old computer with me montor and it work so its not the montor
a even try plug in BFG 8800 GTS in to the other pci-e slot but no luck just comes up on the montor no in put signal the thing is a get no beep when it boots up all lights on all fan on :confused:
you would thought it would start beep if it was me graphisc card?
remove the PCI-E card and use the PCI card alone, should stop it trying to boot from the PCI-E card.
No beeps sounds like a short to me... lost screw down the back of the motherboard, misplaced backing plate on a tower hsf, jam in the psu?
