Have you tried the card in a different computer?
remove the PCI-E card and use the PCI card alone, should stop it trying to boot from the PCI-E card.
No beeps sounds like a short to me... lost screw down the back of the motherboard, misplaced backing plate on a tower hsf, jam in the psu?
Try the old PCI card in there on its own, not with the 8800 in as well as mentioned above.
) you will need to short the power button pins to turn the board on, they don't need to be shorted all the time - or, will your power button cables reach outside the case.Yep it will be safe (make sure its not sitting on a metal table though) you will need to short the power button pins to turn the board on, they don't need to be shorted all the time - or, will your power button cables reach outside the case.
Rob
on me motherboard it has power swith on the board asus blitz formula
so wont ne to short the pins dont really want to do that
.Thats handy, don't worry about shorting the pins.
Rob
