HI there
We have this arriving tomorrow:-
Hyundai W240D 24" Widescreen LCD Monitor - Glossy Black
Finally-an LCD monitor for those of us who want it all. The Hyundai W240D is a 24-inch Diagonal LCD monitor with an astounding 1920x1200 resolution. This next-generation viewing machine has a contrast ratio of 3000:1 and a liquid-fast 2ms gray to gray response time. Tons of technological features like High quality screen rescaling and image-color matching profiles ensure that your content, be it PC or multimedia, is delivered in the exact hue and intensity it was intended. That’s not all-the W240D is a fully HD capable monitor-with an analog capacity for 720p signals and the ability to display a full 1080p digital signal. The Hyundai has rear-mounted connections for DVI, VGA, component and HDMI video connections. HDMI is the new all-digital video and audio connection for today’s most capable HD devices. Enjoy your multimedia, television programs, and sports in true high definition-right from your monitor! Plus the Hyundai W240D can be adjusted vertically, horizontally, and across it’s axis for maximum viewing comfort. And just in case you wanted to mount this monitor on your wall-it’s VESA mounting compliant. The Hyundai W240D 24-inch High-Definition monitor-an LCD for those who want it all.
- 1920 x 1200 (WUXGA+) Optimum Resolution
- High quality screen rescaling capability
- Image Color Matching Profile
- 16.7 Million Colours
- 3000:1 Contrast Ratio
- 2ms Response Time
- 500 cd/m2 Brightness
- 178/178 viewing angles
- One DVI-D Input w/HDCP Support
- One Analogue Input
- One Component Input
- One HDMI Input
- Support VESA Physical Mounting Interface
- Built-in Speaker (3W x 2ch) & Earphone Jack
- High gloss Design & Soft touch key
- 3 Years On-Site Warranty with Hyundai
Price: £339.99+VAT (£399.49 inc VAT)
BUY NOW!!
Badass any chance you can try to confirm exactly what were getting panel wise and if our advertised specification is correct? We supposedly have a UK/Europe exclusive on this panel and it does indeed look superb. When they arrive tomorrow I shall have a closer look at one to try and discover what panel/tech it uses.
