whats the difference between a hydraulic clutch and a "normal" wet/dry one?
And hydralic ones are horrid to do when the slave cylinder is in a horrid position so you end up getting clutch fluid in your eye and mouth. Not nice.
I think you may be confusing two subjects into one there.whats the difference between a hydraulic clutch and a "normal" wet/dry one?
That can't feel / be too healthy![]()
you get used to the taste of brake fluid. *twitches*
Just 2 ways of skinning a cat.but performance/operation is no different? just the feel?
Yuck, you're right thereBut you never get used to the smell of gear oil![]()
They are, it's on a ratchet on the pedal normally.arent cable clutch pedals auto adjusting?
or is that only some?
Replace Mk2 Escort with 100Emk2 scort noob clutchchange. up on ramps, gearbox full, prop out ... eyes, mouth, nose, ears, hair, overalls. I still wake up screaming some nights.![]()
At the end of that day I still had the taste of brake fluid and a stinging eye. Even though I instantly drank a litre of tango orange and rinsed my eye out.
