Stupid PS3 question! lol
  • Thread starter Thread starter sid
  • Start date Start date
sid
sid
9 Feb 2003
London
I have a 11cm shelf in my TV rack,
How high is the Ps3? i've read 10cm so I should be fine yeah?
Also are there any flaps that open to the top which I might not be able to access?
Thank you so much.
sid
I wouldn't recommend it though, you'd want some ventilation space.
Also you probably wouldn't be able to access the memory card compartment as that has an open upwards flap.
If you want your PS3 vertical, I can recommend the 4-Gamers vertical Stand, looks really nice and has a bl00 light :D
Hmm is the front door flap removable?
Also there is plenty of space to the back and sides so ventilation isn't a problem.
Placing vertically is a problem and out of question as I have other items on both sides of Tv shelf.
Are the usb ports in the shelf as well?
sid
Ok well i wont ever be using the card slots anyways, so thats settled then
Will try and pick one up over the weekend.
sid
You can lift the flap up to about the same hight as the centre of the PS3 (tallest bit) and still access all the memory card slots.
