360 Gamepad Accessories
Ok thanks
Going to go for some really good Rechargeable batteries and charger. It's overall better value plus they can be used else where :)
By far the best choice IMO :)
I don't see how, having a play and charge means you never have to change batteries, just plug it in if you're away from the 360 and it stays fully charged.
I can't be arsed swapping batteries even if it does only take a matter of seconds :p
360 controllers, Wii controllers, Wavebirds, etc.
Also useful when mates batteries run out on the 360 and they last so much longer then the rechargeable pack. I also never need to faff about with cables (takes longer than swapping batteries or is messy if you always leave the cable out... I hate wired pads too) and it's not more expensive than a quick charge kit and 2 batteries.
Each to their own though :)
I take it the sprintcharger is made by Uniross?
Yeah.
