Howdy,
I'm hoping someone can help here... well I'm just hoping there is a better way to do this?
I work from home as a Web Developer, and I have been a Windows user for years now, but recently converted to Mac OS X, and am loving it! But there is one VERY annoying thing that I cannot solve, and I am hoping it can be sorted on OS X, otherwise this is something Windows wins hands down with
What is the best way to map network drives on OS X? I have a Windows 2003 server running at home that has all my websites etc on, so I use this everyday. On Vista/XP etc its very simple, you just map the drive and it will appears as X/Y/Z etc in your "My Computer" and I can just use Z: in all my apps to find the files there. The drive stays the forever unless I tell it not to or the server is not running!
Well in OS X I have found the drive on the network I want to connect to, once I authenticate, it appears on my desktop as a server icon. Double clicking this takes me to that drive, great!
Well upon rebooting it disappears, kinda expected, so I reconnect to the server, get it on my desktop, then I drag it to my "Login items" in System Prefs -> Accounts. Now whenever I reboot, enter my password, the drive appear (slowly... but they appear!). My problems are below:
1. Everytime I reboot the folder open up on my desktop and its annoying! I check the "hide" checkbox next to the items in my "Login Items" screen, but this does absolutely nothing? The windows still appear on login? And the drives connect on login? Whats the point in that checkbox?
2. This is the must annoying thing, whenever my MacBook Pro goes to sleep, so do those connections? When I wake the laptop up, blam, all my networked icons gradually disappear from my desktop... I see them doing it? Why is this? I have to then go thru the tedious process of bring them back?
3. I draged the icons to the dock, and I can connect to them there, but I will still have to do this after number 2 happens?
Does anyone else here use Windows drives on their mac? And use them a lot? What is the best way to do this? I just want them to appear on the desktop when I login and stay there no matter what? Can this be done?
Any help/advice on this would be appreciated!
ta
Steve
ta
Steve
) you can create a script in the script editor along the lines of:
