100 wu's
  • Thread starter Thread starter ITR
  • Start date Start date
ITR
ITR
16 Apr 2006
Tamworth
Another small milestone for me this weekend, passed 100 wu's :)
Also on the machine front, rebuilt the e2140 and got it running Ubuntu FF x64 today, so should see a slight ppd boost from win smp.
I must seriously look at replacing the x1950pro thou, the power consumption is beginning to worry me :eek: I could run 2x C2D smps for 3k + ppd and only use slightly more juice than the GPU is using for 600ppd.
Points per Watt is shocking for GPU folding :mad:
Just for a bit of comparison, upgrading from Win SMP (on XP 32bit) to 64bit Linux has chopped 1min off the frame times for a 2653 wu, so speeding up the wu by over 1h30min.
Also of interest i have 2 machines here folding the same wu (2653). Both machines are identical bar the CPUs (Asus P5B + 1 Gb PC8500).
The E6600 @ 2.88Ghz is giving 1643ppd - Vista Ulti 32bit
The E2140 @ 3Ghz is giving 1712ppd - Ubuntu FF 64bit
Enough rambling from me... :-)
According to my ****** power meter its drawing close to 430w! :eek: And thats using a good quality PSU too.
Its overclocked from stock 600Mhz Core to 618Mhz, and the P4 CPU from 2.8 to 3.2Ghz... Im sure a chunk of the power is due to the 'Presshot' P4 tho...
By the power of grayskull! :eek:
By comparison, my ps3 folds at 200watts for 900ppd and my iMac folds at 55watts (screen off) for 700ppd.
My e6300 (OC to 2.5ghz), 2gb RAM, x1950 Pro folds at 175watts running 2 standard clients.
430watts is insane!
