Cutting compound to remove lacquer overspray
30 Sep 2003
Norwich
Fixed up some lacquer peel around my front mud flaps today. Went pretty well and I'm pleased with how its turned out but I've got a touch of overspray which makes the surrounding paint look a little rough.
On the can it says wait 2 weeks then use a cutting compound.
What would you recommend to use? The safest one that will do the job would be good :o
I've got some 3M Perfect-It III fine but I'm guessing thats not going to be up to the job?
Use some fine wet and dry (1200/1500 grit) to flat the lacquer this will also get rid of overspray (dont worry about wet and drying over the current lacquer it will t-cut back to normal). 2 Week is advised but 24 hours should be fine if you havent put it on too thick. t-cut will do. This will make it shiney.
I've used 3M's stuff before on a pink 155, it's hard work, but it's as good, if not better, than T-cut.
Hmmm... I polished my whole car with the 3M stuff that I've got and it did quite a good job. Hologramed it up quite spectacularly too but my 3M Imperial hand glaze soon sorted that out. Not too sure its up to this job though although I guess it can't hurt to try.
I would wet and dry it but it was bad enough doing the flaky edges before spraying it. Having never done it before I honestly wasn't expecting the bodywork to go completely white, bum clenching moment right there :o
If I could use a compound to do it I'd feel much happier.
With regards to T-cut, I got on great with the original stuff on my mums car but T-Cut metallic seemed crap when I used it :confused:
I've removed soft paint overspray with Isopropyl alcohol before with no damage to the paintwork/lacquer.
T-cut isn't "bad", it's just a weaker cutting compound, which in some cases is more suitable.
On that scale would Brasso be excellent?
For your exhaust, maybe. I used to use it a lot and it worked fine. However there are better methods than T Cut as the abrasives dont break down to leave a proper finish.
Try a decent claybar first, it's pretty damn good at removing overspray without any cutting whatsoever.
I like your thinking and I'll give that a try next time :D
Well as I'm impatient and had some time on my hands this afternoon I thought I'd give it a shot with my 3M Perfect It. Now this stuff is about as abrasive as a babys bum cheek but with plenty of elbow grease and working it until it warmed up ever so slightly it seems to have done the job :cool:
