Spec Check - £900 build
Caporegime
19 May 2004
Nordfriesland, Germany
This for use as a development PC. Quad core is a must, as is decent disk access and a redundant RAID array (I'm planning on use RAID 5 on those three discs). It also needs respectable graphics performance, but I can live with being off the bleeding edge. I also need Remote Desktop so I'm pretty much stuck with Vista Ultimate (Business would also do fine, but OC don't do it). I'm going to be bringing a DVD re-writer and (if I need it) a floppy drive over from older PCs.
I plan on overclocking the CPU to about 2.8-3.0 GHz. A quiet running and stable computer are both more important than ultimate performance. I have £900 to spend as a hard limit.
Thoughts?
(edit) Oh, and I've got keyboard, monitors and mouse already so I don't need those either.
Could swap out the spinpoint's for AAKS, since the AAKS have 16mb cache and only £2 more per drive, same size too. Would probably also drop the OcUK RAM and get the OCZ stuff on this week only since it's only £3 more. I'd also drop the AS5 and get some MX-1 which is arguably better and £4 cheaper.
Other than that the system looks great.
All ordered now :)
I went for the OCZ memory, and the 7200.10 drives, and the MX-1 compound. All nudged in just under the £900.
