- 18 Oct 2002
There were problems with some of the early batches of AUO panels but it appears the chances of getting one are a lot lower now.
ordered
Intel® Core™ 2 Duo T7300 Processor (2.0GHz,800MHz,4MB L2 cache)
Base Warranty - 1 Year Business Hardware Support
15.4" Wide Screen WXGA (1280 x 800) Display
Matte Jet Black without Camera
2048MB 667MHz Dual Channel DDR2 SDRAM (2x1024)
160GB (5400RPM) SATA Hard Drive
256MB nVidia® GeForce® 8600M GT
Fixed Internal 8X DVD+/-RW Drive
hope ill be happy![]()
Nice. I'm looking to order something very similar to this myself. Did you go for win xp or vista?
), tried it again with sound, but only get none after the intro
I heard it briefly this morning on some in the ear headphones but it vanished. All i can remember doing is installing the Turbo Memory drivers.I downloaded the demo and sound was working perfectly on that.
Tell me how you got rid of CPU whine!! Mine disappears when you select the Power Saver power plan but ideally I'd like to leave it on High Performance.
At the most a laptop should only really be used for "light gaming", forcing games like bioshock onto these small systems doesnt really do any good, remember at the end of the day this particular laptop is designed with small businesses in mind so i wouldn't expect top notch gaming performance, might be ok for pinball or minesweep lol.
At first the CPU whine was tolerable, now I can't stand it! The more time I spend at my laptop the worse it gets.
What happens is when the CPU goes into a low power state, this annoying whine becomes clearly heard. It could be a faulty motherboard, CPU or Dell cutting costs and sticking in cheap components.
Anyway, I used the above software, checked the Disable C4 Mode and if by magic, the whine vanished.
I've got a Dell technical support person coming round to fix my other issue later today.
Remember I was telling you about the screen making a buzz/hum noise on every screen brightness setting other than max? Well, the inverter that steps up and down the voltage to power the backlight tubes needs replacing. Will be getting the whole panel replaced today.
I'm tempted to phone Dell back up on Monday and get this CPU Whine issue resolved as well.
