When I Wii - it's noisy!
14 Jul 2003
My Wii has started to play up after a prolonged gaming session at the weekend at a friends house.
Initially it was simply drive read errors, I assumed it was the disk which had been in and used for a good two hours, so I took it out and turned everything off. As it happens it was a few hours before we started playing again, this time with a new game (Brain academy), straight away I could hear the disk spinning up - fairly loudly and ejected it, put another disk in (mario striker) which did the same.
Checked the fan at the back - nothing in it making a noise.
Tried a further 3 disks, most of which are brand new and they all do the same. Whether it's on it's side or lying flat the Wii is noisy when a disk is in - silent when one isn't.
It's got the latest firmware etc etc but frankly it's the drive, you can hear it spinning up just like any knackered PC drive does.
My thoughts are its heat related, my Wii sits horizontally and I wouldn't be surprised if a component has overheated, screw worked it's way loose etc and is causing this.
I've e-mailed nintendo about it, I'll see if they give me any ideas, the unit is less than two months old.
I doubt it, when I took it apart all the screws had very fine threads and heat shouldn't affect the drive. I just think it's a dodgy drive rather than heat issues.
Nintendo customer service rocks.
An update from me - Walked into <insert name of a well known high street retailer>, handed over my knackered console, they didn't even plug it in and just gave me a brand new one. Said it was only the 2nd one they'd ever had back so they really weren't bothered about testing it!
New one works fine :)
That's pretty decent, I'd usually expect to hear some reluctance to exchange the console. :)
You should probably edit out the shop name though! (Competitor)
