CCleaner 2.0 Beta released
19 Oct 2004
Newcastle Upon Tyne
Not sure if this has already been posted (couldnt see it) but can't check because search isn't enabled.
http://www.ccleaner.com/ccleaner-20
Its only beta but is a complete re-write of the old program.
Wonder if this version doesn't crash when secure wiping in Vista :S
Change log:
* Complete rebuild in C++
With the requirements for a portable version, 64-bit compatibility and Windows Vista increasing against the limitations of the old architecture. We decided to rebuild the entire CCleaner application in highly optimized C++.
* Faster analyzing and cleaning
Each scanning process was rewritten from scratch and fully optimized. The result being a noticeable speed increase in all areas.
* Portable
CCleaner can now run from a USB thumbdrive and be installed/run on a computer without a complicated setup process.
* Compact
The rewrite removed all external file dependencies, so the main EXE is now half the size of the original program and support files.
* Redesigned User Interface
The original CCleaner user interface was looking a little dated, so the GUI was redesigned with a modern look, but without sacrificing speed or usability. New icons were created for the interface and the main program icon was updated with a more modern style.
* Exclusions
It is now possible to specify files, folders and registry keys to ignore from the cleaning process.
* Loads of little tweaks
Too numerous to mention them all separately, we've tried to improve CCleaner in all areas.
why does anyone need secure deletion, unless you're selling the current pc
if so, dban it, then reinstall os
Customers sometimes send me their info including name, address, credit card details and they have to be securely deleted after we use them.
It's a data protection thing !
At the top of http://www.ccleaner.com/ccleaner-20
CCleaner v2.00.500 Final
- Starts on Vista with Admin permissions where available.
- Fixed bug in registry cleaner with extended characters.
- Improved global exception handling and reporting.
- Fixed missing translated strings.
- Fixed minor bug in Antivir cleaning.
- Updated translations.
- Minor tweaks and fixes.
Then at the bottom...
Warning: This is beta software, so we don't recommend you install it, unless you accept and understand that this version may not work 100% as intended.
We suggest that most users wait until the final release is made available.
because I don't want people finding my pron url's why else :rolleyes::o:p
Then at the bottom...:/
That's pretty much a standerd warning for any beta tbh.
edit - ahhh, I see what your getting at, yeh that's strange, says it's a final version but then has a beta warning at the bottom :confused:.
Thanks, the old version was very buggy in Vista, it picked up load of crap and removed it but when i rescanned it was still there so must not been clearing the data properly.
Who knows this one works great!
