- 11 Oct 2005
- Doncaster
Since I purchased my Lian Li v2100+2 case I have tried everything to get it as silent as I can.
The main problem is the vibrations going through the case VIA the hard drives and sometimes the DVDRW. I have even put blue tack on each side of the DVDRW to try and absorb some of the vibrations from the drive. I have 8 SATA drives in the bottom of the case (only 5 are on at one time). I have also got 2 drives in the 5.25bays these are inside the Antec HD coolers (without the fans there were to noisy).
I have also changed the front & back 120mm fans to Sharkoon 1000 Silent Eagle. I just can’t stop the vibrations at all going through the case…does anyone have any idea what I can do to stop these vibrations. If I could stop them then I would be a happy man.
