How often you guys have to inflate your tyres to keep them at your preferred pressure level? I'm asking because on buying my car around April/May time (E60 530D, 245/45/R17 runflats, Bridgestone RE040's) I inflated the tyres around June-July time to a bit below the recommended pressures on the car.
Rears should be max 3.1 bar, fronts should be 2.6. The rear left was at 2 bar, 0.5 bar below the rear right, and also lower than the fronts which is obviously quite a drop.
I got a puncture warning on the I-drive yesterday but didn't see anything obvious, went to check the tyre pressures and saw that they had all fallen by 0.6 - 0.7 bar and again the rear left was unusually lower. I'd imagine the rear left set off the warning even though it looked visibly fine. I pumped them all up, reset the tyre pressure indicator on the i-drive and all is well again. But is 2 - 3 months not rather quick for tyre pressures to drop so much? If so, what's causing this. I like throwing this car around corners, does this have much effect, or should I not have inflated them as much...
I'm due a tyre change shortly anyhow (rears probably overdue), and was tempted to just pop down when I got the puncture warning yesterday - anything I should get them to check out?
My dad checks the pressures on his wee C-class about twice a year and they never need a lot of filling.
Then again that would mean adjusting them 5 times a day sometimes
