Almost everybody does. That's the normal direction, no?Has anyone else got this heatsink with the fan facing the memory???
It will fit easily. On my DS3 the Freezer 64's fan overlaps slightly with the memory but it has about a centimetre of clearance above it.
I don't think it will fit with that Corsair memory, or at the very least you will have some problem fitting the fan back on once the Heatsink is attached, the fan will be pushing against the mem I should imagine?Thats what im wrorried about, cos my mem is higher then normal memory?
Speedy, do yourself a favour and forget that cooler. I have used two of them and found one to be average and the othe snapped as I was installing it?Thie problem is, I need a really good cooler cos my opty at stock speed reaches over the 70c mark, and its not todo with airflow in my case
You could say the same for the stock AMD cooler though Raikiri?And yet thousands have had no issue with them in the last couple of years...
