Hi there
If price is not a worry then why not go for one of these:-
NEC MultiSync® LCD2690WUXi 26" Widescreen LCD Monitor - Black
The new MultiSync LCD2690WUXi display from NEC display solutions boast a 26" display size, 16:10 widescreen format and a resolution 1920x1200, ensuring extremely high image quality. It is specifically designed for professional use for graphic design, CAD/CAM and DTP applications. The large screen size, widescreen format, and accurate colour reproduction also make the product ideal for the display of financial information, document processing, public display, broadcasting, gaming, home cinema and mult-media applications.
More and more companies are looking to wide format as the display of the future. Many are evaluating the move to Microsoft Vista and recognise that wide format displays will offer the extra screen space required to display Vista 'gadgets' and tool bars alongside regular applications. NEC's wide format displays will also fulfill requirements to invest in energy saving technologies and to improve work place ergonomics for staff helping to increase productivity.
The new flagship product within the NEC Display Solutions high-end series widescreen range offers some of the most sophisticated display technology available. It's 26" screen allows two A4 pages to be viewed side by side, with extra space for additional tools for windows. Pin-sharp picture quality is assured thanks to the 1920x1200 resolution and a larger distance between pixels (0,287mm) reduces eye strain. The new H-IPS A-TW Pol panel offers exceptionally wide horizontal and vertical viewing angles of 178% without colour shift. This ensure an excellent view of the panel from any angle, making the product ideal where multi-monitor applications are needed such as financial trading.
- 1920 x 1200 (WSXGA) Optimum Resolution
- 16.7 Million Colours
- 800:1 Contrast Ratio
- 8ms Response Time
- Overdrive off/on option
- Adjustable Backlight (Great for improving blacks in dark rooms)
- 400 cd/m2 Brightness (Adjustable)
- One Analogue Input
- Two DVI Inputs with HDCP (1x DVI-I & 1x DVI-D)
- Full range of aspect modes (1:1, Fill, Aspect mode and custom)
- VESA mounting compatible
- Warranty : 3 years onsite supplied by Manufacturer
Price: £619.99+VAT (£728.49 inc VAT)
BUY NOW!!
Reviews rate the quality above the DELL's, its not as expensive as the Eizo's but probably similar in quality and its another 2" bigger.
