New Graphics Card
I assume you're using PCI-e. At that price the best you can do is an X1950 Pro 512 MiB. If you could stretch a bit more you could get an 8800 GTS 320, a much better card, for £178.59.
Lo peeps.
Dont know but that made me laugh. :p
As You can Probably tell by the title of the Thread I need a new card as my
X800 Refuses to run BIOSHOCK
I have £120 and would appreciate some suggestions:p
You could either try and get a second hand X1950XT or buy a X1950Pro. Depending on the res that you play at either the 256mb or 512mb version.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-063-OK&groupid=701&catid=56&subcat=404
http://www.overclockers.co.uk/showproduct.php?prodid=GX-064-OK&groupid=701&catid=56&subcat=404
Or if your willing to stretch to £180, this will do you nicely:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-054-OK&groupid=701&catid=56&subcat=927
The x1950 will do you proud man.
See your sig. Has that got anything to do with a game name btw?. I know a Call of Duty player called Cunning Stunts.
Ok I was persuaded to go that lil extra and ordered this Beast
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
I feel Much more confident that this'll run Bioshock :D
Welcome to the 8800 club :D
I never looked back since getting mine as an upgrade to a x800xt
Just hit the same problem with my x850, graphics are all scrambled when game loads.
Bioshock needs Shader Model 3.0 to run but the x800's only do Shader Model 2.0b. There is a hack to get it running on Shader Model 2.0 but the results aren't so pretty. I'm going to hold out playing till I get my new system next month.
http://www.paolofranchini.com/shshock/viewforum.php?f=1
Yeah thats my problem but that's all gonna be sorted when I get my shiny new 8800 tomorrow:p
