Samsung DVD-R135 DVD Recorder help please
1 Dec 2005
Stoke on Trent
Spec here :
http://www.samsung.com/au/products/dvdrecorder/dvdrecorder/dvd_r135.asp
Picked this up 2nd hand for £65 as i was doing a mate a favour.
Basically im having a hell of a time trying to find media it likes recording on.
Write once media ive only got ritek GO dye discs which id of thought it would be ok with. At first it was but now it wont read them ( although my son did grab the spindle of dvds and scatter them over the floor while chewing on one or two :eek: )
Rewritables ive tried Tuffdisc 2x and Imation 4x. Both get spat out and says discs is unplayable. Both sorts work fine in the PC
Am i missing something obvious here as it seems not to like any media i try in it. Playback of DVDs and Video CDs is fine tho so i dont think the player is faulty.
Can anyone recommend me some decent discs to try
Thanks
you did buy verbatim DVD-R and not DVD+R? As your recorder seems to only support -R
Of course i did lol :p
I went my dads earlier and borrowed one if his discs. Worked first time as well, only problem is ive no idea what they are as they were prinables :p
