Yep.... its another spec check!
4 Sep 2007
i have included mouse, keyboard etc as its a complete new build only thing i currently have is the monitor, which i got for free :). please let me know what you think, any suggestions will be appreciated.
want to keep case, case window, mobo, cpu, mouse, keyboard, headset and want at least 2 HDD totalling >750gb. thanks for quick reply, budget is around 1200+1300. 1300 at a very big stretch.
that headset is crap m8 get somthign thats is built for sound quality like sennheisers there brilliant, someone on here just sent there fatal1ty headset back as it was so uncumfy
swap the 2 drives for the western digital 500gb aaks drives.
could drop the psu to the 520 model as it will handle what is included without any problems.
swap the graphics card for the OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM.
Definetly, no need to get a 620w unless you are planning crossfire/sli.
just to clarify the reason for me saying to switch the 620 to the 520, it allows extra cash for the ocuk gtx which is only about £30 ish dearer than the gts spec'd and you'll see better performance going with the gtx over the 620 psu :)
