I just need a quick bit of help before I waste my money. I'm having a problem with my build where no bios info is displayed and nothing boots up (see here for info).
Rang up OcUK support who said it sounded like it needed a bios update...only problem is if I can't switch my pc on or even load up the bios in the first place, how can I update it?! Bit of a tricky situation!
So I'm going to try and buy some cheapo ram from town later and see if that kicks it into life.
My two questions are:
1. Has anyone else used it with 1066MHz ram? It says it's supported on the website but I guess if they've added it to a later bios update this could be why.
2. If you remove everything from the mobo and switch the pc on, what happens? Do you get a blank screen or bios info?
Q.2 is quite important, as mine is just blank, thus if bios info is displayed even with nothing plugged in, my mobo is at fault and new ram won't help.
I'm sure the processor (Q6600) is supported as loads of other people in the SFF section have pieced together builds with the same cpu and mobo as me.
Thanks for any replies
