Amazing Deals on NEC 26" Professional LCD and DELL 30" LCD Monitors!!
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
First of all, anyone who is not familar with the NEC LCD2690WUXi may want to read this review:-
http://www.trustedreviews.com/displays/review/2007/04/12/NEC-MultiSync-LCD2690WUXi/p1
Too put it simply if you want the absolute best in image quality then the NEC 26" even can put the DELL's to shame, it really is a stonking panel and the good news is OcUK has a price thats over £200 cheaper than most of our competitors, check it out:-
NEC MultiSync® LCD2690WUXi 26" Widescreen LCD Monitor - Black
The new MultiSync LCD2690WUXi display from NEC display solutions boast a 26" display size, 16:10 widescreen format and a resolution 1920x1200, ensuring extremely high image quality. It is specifically designed for professional use for graphic design, CAD/CAM and DTP applications. The large screen size, widescreen format, and accurate colour reproduction also make the product ideal for the display of financial information, document processing, public display, broadcasting, gaming, home cinema and mult-media applications.
More and more companies are looking to wide format as the display of the future. Many are evaluating the move to Microsoft Vista and recognise that wide format displays will offer the extra screen space required to display Vista 'gadgets' and tool bars alongside regular applications. NEC's wide format displays will also fulfill requirements to invest in energy saving technologies and to improve work place ergonomics for staff helping to increase productivity.
The new flagship product within the NEC Display Solutions high-end series widescreen range offers some of the most sophisticated display technology available. It's 26" screen allows two A4 pages to be viewed side by side, with extra space for additional tools for windows. Pin-sharp picture quality is assured thanks to the 1920x1200 resolution and a larger distance between pixels (0,287mm) reduces eye strain. The new H-IPS A-TW Pol panel offers exceptionally wide horizontal and vertical viewing angles of 178% without colour shift. This ensure an excellent view of the panel from any angle, making the product ideal where multi-monitor applications are needed such as financial trading.
- 1920 x 1200 (WSXGA) Optimum Resolution
- 16.7 Million Colours
- 800:1 Contrast Ratio
- 8ms Response Time
- Overdrive off/on option
- Adjustable Backlight (Great for improving blacks in dark rooms)
- 400 cd/m2 Brightness (Adjustable)
- One Analogue Input
- Two DVI Inputs with HDCP (1x DVI-I & 1x DVI-D)
- Full range of aspect modes (1:1, Fill, Aspect mode and custom)
- VESA mounting compatible
- Warranty : 3 years onsite supplied by Manufacturer
Price: £619.99+VAT (£728.49 inc VAT)
BUY NOW!!
For our next offer, those seeking the ultimate in resolution and size we have a very competitive price on the DELL 3007WFP-HC LCD Monitor:-
Dell Ultrasharp 3007WFP-HC 30" Widescreen LCD Monitor - Midnight Grey
The Dell™ UltraSharp™ 3007WFP-HC* 30-inch widescreen LCD flat panel monitor is a wide-aspect desktop display that enriches the performance of LCD displays with its stylish design and enhanced functionality. Delivering a high 92% colour gamut, 2560x1600 (WQXGA) resolution and a fast 8ms (grey-to-grey) response time1, the UltraSharp™ 3007WFP-HC* monitor enables crisp, clear images, ideal for fast motion video and graphics and is optimized for use in video editing, pre-press editing, 3D modeling, CAD, visualization, digital photography and gaming applications. The UltraSharp™ 3007WFP-HC* monitor features 4 x USB 2.0 ports (2 x USB ports located on the side) . This performance, 30-inch widescreen flat panel monitor is compatible with the Dell™ AS501 Soundbar (sold separately) providing multimedia capabilities to the flat panel display. Dell ™ branded monitors undergo exhaustive testing for performance, reliability, durability and compatibility with Dell™ systems.
*The Dell™ UltraSharp™ 3007WFP-HC monitor requires a dual-link DVI-D graphic card to support the WQXGA (2560x1600) resolution and is optimized to work with select Dell™ XPS Desktops and Precision WorkStations or systems that support a WQXGA resolution.
8ms (typical) response time is based on grey-to-grey measurement settings, typical of fast motion video used in gaming and DVD movies.
- 30" Widescreen
- About 52.5% more screen area than Dell 2405FPW
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1000:1 Contrast Ratio
- 12ms Response Time (8ms Grey-TO-Grey)
- 300 cd/m2 Brightness
- One DVI-D Input with HDCP support
- Height adjustable stand (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer (Call DELL on 0870 9080800 and have the work number from the original packaging handy)
- Before purchasing this product make sure you have a compatible graphics card that supports Dual Link DVI / DVI-D such cards are the ATI X1300/X1600/X1800/X1900 series and NVIDIA 7800 series graphics cards.
- This product is not compatible with AGP cards
Price: £714.99+VAT (£840.11 inc VAT)
BUY NOW!!
Hi there
If your looking for a suitable graphics card to power these monitors, especially if your playing games then check out this deal on the NVIDIA 8800 GTX 768MB we have:-
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The WinFast® PX8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 575MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1800MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 1yr Warranty!
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Price: £247.99+VAT (£291.39 inc VAT)
BUY NOW!!
Looks like a very nice screen and the image quality will be superb as most of Nec screens.
Very exepensive though since it has the same res as a 24inch screen but £250 more (round abouts).
Though i do like the price of that GTX. Very nice Gibbo. ;)
Hi there
The NEC is worth every penny, read the review in full. :)
From what I can see were around £200 cheaper than most if not all our competitors on the NEC and as such I would not say its over-priced, its just expensive but you get what you pay for. :)
