MOH airbourne PC install help
5 Aug 2006
Derbyshire
Hi, I have airbourne and when trying to install it I am having problems:(.
The game auto runs, I select install, enter serial and click next and then a box appears headed 'microsoft visual c++ 2005', the box has a progress bar (same as the progress bar you get when copying a file) which fills up then emtpies and closes the install. no error messages, nothing.
Specs as sig and Im using XP at the mo.
Any help at all ??
i had a similar problem, it would let me enter serial then it installed aegis drivers then it went off with no errors .. very annoying
i deleted the aegis(sp) drivers and rebooted, i had to try a few times before it started installing , and boy does it take time ,, sorry i cant pinpoint how to fix,
vista home prem btw
Delete current Ageia drivers and let the game install its own. Worked for me in the demo and for many others too.
windows firewall is on and I do share an internet connection (wireless router) but what setting do I need to change on that. thanks
EDIT: this is really starting to hack me off as I did buy this game!
Copied off EA Forum.....
Install won’t complete. It rolls back at the end
PLEASE NOTE: During the install, the installer attempts to add MOHA to the firewall exception list regardless if the firewall is enabled or not. This depends on the firewall service being available to windows. This service is enabled by default on XP and continues to run, even if the user sets the firewall status to off. If it is disabled completely in the services list, then we see the failure.
To enable the service: Start Menu -> run -> “services. msc”
The name of the service is “Windows Firewall/Internet Connection Sharing (ICS)”
To start it, right click on the service name and click “Start” in the menu. Then proceed to install the game normally.
Thanks to Bake1507
Mike
