Hi there
Some graphics deals on This Week Only for you guys:-
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The WinFast® PX8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 575MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1800MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 1yr Warranty!
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Price: £247.99+VAT (£291.39 inc VAT)
BUY NOW!!
OcUK ATI Radeon X1950 Pro 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Targeting the adrenaline addicted minds of the avid gamers with jaw-dropping performance, OcUK delivers enthusiast-class features to the mainstream with the RADEON X1950 PRO. The OcUK X1950 PRO promises to awaken the senses and free the imagination from the shackles of PC hardware limitations while remaining affordable. The OcUK family of products are synonymous with extreme performance and reliability. The OcUK X1950 PRO makes for a welcome addition to the family with its robust hardware offerings such as: the industry acclaimed X1950 GPU, 512MB of GDDR3 of onboard memory, CrossFire support, DirectX and OpenGL acceleration along with enhanced support for the Windows Vista™ 3D environment. Experience the price vs. performance champion with the OcUK X1950 PRO!
- Powered by ATI Radeon X1950 PRO - 575MHz (RV570 80nm)
- 512MB-256bit 8 channel GDDR3 memory - 1.30GHz
- 36 Pixel shader processor
- Ultra-threaded SM 3.0 Engine
- 512-bit Ring-bus
- Low power consumption (Consumes 60W less than equivalent X1900 XT)
- Crossfire2 READY (Internal Crossfire Connection) - Just buy another X1950 Pro for Crossfire!!
Price: £67.99+VAT (£79.89 inc VAT)
BUY NOW!!
HIS ATI Radeon X1950 Pro ICEQ 3 V2 TURBO SILENT Heatpipe 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (H195PRQT512DD-R)
Is your rig ready for the onslaught of next generation games? It will be with the HIS X1950 Pro. Designed from the ground up to deliver maximum graphical detail at ultra-high frame rates, the HIS X1950's state-of-the-art architecture includes an ultra-threaded engine for unparalleled shader performance. In addition, it is CrossFire2 ready which no longer requires external cables, allowing your greatest multi-GPU fantasies to come true. The HIS X1950 ups the ante with Avivo?video and display technology that delivers movies, games, and photos in high-definition with stunning color and realism. The IceQ3 cooling system draws cool air from inside the case and exhausts warm air outwards. This prevents the fan from recycling warm air to cool the VPU, which increases cooling performance and lower the air temperature inside the case significantly.
X1900 XT performance but with the advantage of much lower power consumption, cooler running and new Internal Crossfire mode makes the X1950 Pro a cracking card for very little money and one that packs a serious punch when you buy two cards and run in Crossfire mode via the internal bridge.
- Powered by ATI Radeon X1950 PRO - 575MHz (RV570 80nm) (620MHz Turbo)
- 512MB-256bit 8 channel GDDR3 memory - 1.38GHz (1480MHz Turbo)
- 512-bit Ring-bus
- HDCP Ready!!
Price: £94.99+VAT (£111.61 inc VAT)
BUY NOW!!
- Shader Model 4.0
- HDCP Enabled!!
- 1yr Warranty!
BUY NOW!!
- 512-bit Ring-bus
BUY NOW!!
- 512-bit Ring-bus
- HDCP Ready!!
BUY NOW!!
