Lightroom 1.2 update out
18 Oct 2002
Chesterfield
http://www.adobe.com/support/downloads/thankyou.jsp?ftpID=3728&fileID=3506
The Adobe® Photoshop® Lightroom® 1.2 update includes these enhancements:
• Corrections for several issues including XMP auto-write performance, Windows Vistaᆴ grid display errors, and noise reduction for Bayer patterned sensors
• Additional camera support for the Canon EOS 40D, Fuji FinePix IS-1, Olympus EVOLT E-510, Panasonic DMC-FZ18, and more
● Lightroom 1.1 catalogs with user-specified sort order could not be imported into another catalog
● Lightroom 1.1 for Windows could at times display gray boxes instead of image thumbnails
● The preference to write XMP metadata automatically in Lightroom 1.1 could attempt to write metadata indefinitely for
offline images causing significant performance problems
● Images could be dropped from the Quick Collection upon reordering of the source folder
● Catalogs could not be exported to drives smaller than 250MB
● The Web Module was not accessible in Lightroom 1.1 on the Macintosh platform when Lightroom was installed on
case-sensitive volumes such as the Case Sensitive HFS+ (Journaled) volume
● Errors occurred exporting to a Linux SMB network volume
● Scroll position in the grid view was not maintained when changing the view option using the J shortcut key
● The tokens for image number and image count were not displaying properly in the Slideshow module
● The metadata panel could display incorrectly on Windows
● Slideshows on the Macintosh platform did not display properly when a 256MB ATI graphics card was connected to 30
" LCD
● The Lightroom 1.1 Web module export did not position the copyright tag in the same location displayed in the preview
● The auto-eject functionality on Windows ejected the card reader device in addition to the card
● Noise reduction adjustment for all cameras with Bayer Pattern sensor: The base point noise reduction applied at the
demosaic stage of raw processing has been reduced. The resulting effect is that images with zero luminance noise
reduction applied in Lightroom 1.2 will contain more noise than the identical settings in Lightroom 1.1 but less noise
than identical settings in Lightroom 1.0.
● 1:1 previews were not discarded according to the timing set in the Lightroom preferences
● 1:1 previews are not built for an entire set of images when requested after import
Will this solve the yellow/warm cast that Lightroom seems to add to my photo viewing (exporting is fine). Will have to wait and see tonight!
If it does, then I will buy Lightroom, if not I will continue using Picassa and CS2.
Your the only person ive seen with that problem. Have you emailed Adobe at all?
Ah good stuff, the card reader ejecting issue was one of the first things i noticed after the 1.1 update, will be handy to be able to use that now :)
i often have an issue in lightroom where it will take AGES (about 2 minutes) to properly load the image. will this patch solve this i wonder?
