Good heel-and-toe video
I heel toe and almost all manuals i drive now :o
Best way to learn is in a car you know you can trash and rag :D
Good ol krusty, ill never forget you're awkward pedal lay out :(
Saves your synchro. rings the job of speeding up the main shaft to match the lay shaft.
But it's still completely pointless in a modern synchro gearbox. Unless your synchros are worn, there is simply no need to double de-clutch.
Double de-clutch is a waste of time, period. As for LFB, people use it for different things. Myself, I use it to scrub of speed while trying not to unsettle the car, other times I don't bother as unsettling the rear end is exactly what I'm trying to do.
I can see lot's of lads driving around now watching their feet instead of the road ahead...
