right this is doing my head in.
when i'm downloading anything off the net every now and again i get a BSOD, the computer then restarts and boots back into windows. the BSOD is never up longer enough to catch the event ID, so the only thing i can go by is the event viewer in windows.
prior to every crash there is a common event:
Tcpip Event ID: 4201
The system detected that network adapter NVIDIA..controller - Packet Scheduler Miniport was connected to the network, and has initated normal operation over the network adapter.
is this causing the crash.
i have an Asus A8n-SLI dlx, and i use. the onboard network card, this is connected to a belkin router (with a cable) then the router goes through virgin media BB modem.
there is one other computer connected to the network via wireless.
i'm running XP sp2. and the original nvidia network drivers.
it happens only when i'm downloading - presumably putting a larger than browsing load on the net.
any ideas?
thanks in advance,
Josh
any ideas?
thanks in advance,
Josh
) to sort it out. i'm sure its a driver/ netowrk on mobo issue as this is the first time i have hard wired to broadband and nothing else has changed.
