Hi everybody,
Right, I have a problem with my 2 Year old setup that is kind of hard to pinpoint. So I thought it might be a good idea for some of you guys to share your knowledge of what you think is dying in my PC without me spending hundreds on parts I might not need.
WARNING this 1st post might get a little long but I wanna try and cover all bases as to what the problem might be. Anyway:
Currently I am running :
Abit AN8 Ultra (latest Bios)
AMD64 +3700
Crucial Ballistix 1GB DDR400 Pc3200 (BL6464Z402)
Winfast 6800GT Ultra PCI-E
Antec Phantom 300W (Not the most powerfull supply but I like the fanless aspect
Antec P180 Case
Seagate 300GB SATA 7200rpm HDD
Audigy2 Platinum Sound card
WinXP
Apart from a few memory problems I had with a bad batch of Ballistix memory, the system has run as smooth as ever with hardly any crashes etc.
Until last week...
I was using ITunes and a couple of IE pages open when the system turned off. Tried turning it back on but the fans just whirred a bit and I got no Video or POST beep.
So I opened it all up, took out all unneccessary components and still it would not pass the POST. Giving me an error code of 0.4. User guide mentions something about Memory error. I noticed that one of the 3 case fans was not spinning, only on higher voltages does it start to spin! I also heard the Video card's fan which didn't sound to healthy as it kept trying to spin up like a HDD and was a bit noisy.
So I swapped the Ballistix with different memory in different combinations and still had the same error. I borrowed an old PCI video card which got it to start booting Windows. It got to a chkdsk screen so I thought I would let it run the scan, however it suddenly jumped to a black screen with mouse pointer and then rebooted.
It then continuously rebooted without getting into full windows. All Safe Modes etc would reboot.
I then used a spare SATA HDD to install a fresh copy of Windows to see if I could salvage any data off the old HDD incase it got corrupted in any way. (All my data is backed up every couple of days anyway but would be nice if I didn't have to rebuild Windows yet again)
So I got to the install options for Win XP and as it was formatting, came back with an error saying that the (new, spare and fully working) drive cannot have its partition formatted as the drive is damaged !!!
I tried an old IDE drive and that booted once then rebooted and couldn't find NTLDR !
Since then I have downloaded the HDDs' manufacturors DOS utilities to perform tests and have even zero written to the first and last sectors of the SATA drive. I then formatted it with this utlity and tried to install WinXP. It copied the files and then on first reboot it came back with an Invalid Partition Table.
So after pulling all my hair out what do you guys think could be the problem?
I don't think its the HDD's although now I think there is something wrong with the partition tables. (I won't put my orginial HDD back in as I don't want it to get corrupted if there is something wrong with the PC).
I reckon my gfx card is dead anyway but have no way of knowing as I have no other rig with PCI-E.
But even when its not in the system im still having trouble. Could the main culprit be a faulty motherboard after the PC initially died? Or could it be the lame power supply which might not be powerful enough (it has worked ok so far though).
I would like to hear your view on the best way to pinpoint the problems from the symptoms above as these sort of problems are the worst!! Or even if you guys know of any good utilities I can run to test out the system from DOS woudl be helpful.
Any thoughts or help would be appreciated.
Thanks for reading !
AMD64 +3700
)Antec P180 Case
WinXP
Until last week...
Sods law as well for the motherboard to possibly break not long after the warranty expires.
