Shes quite recognisable.. Is that an on set photo ?
My boats bigger then your boat![]()
Does it have Vtec ?
The first boat looks way bigger, you lose!I see your boat and raise you:
isn't that the huge thing that's basically acting like an oil rig these days?
No but does have a electrical turbine for each cylinder to increase the charge..
IIRC something like 102 rpm max but some stupid amount of torque!
Total engine weight: 2300 tons (The crankshaft alone weighs
300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
http://people.bath.ac.uk/ccsshb/12cyl/
Some facts on the 14 cylinder version:
Code:Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.) Length: 89 feet Height: 44 feet Maximum power: 108,920 hp at 102 rpm Maximum torque: 5,608,312 lb/ft at 102rpm
