TO ANYONE WHO WORKS IN OCUK SHOP
ive sent them a webnote about this monitor to confirm if it is VGA + DVI or just VGA as i want one, but need the dual input
Aww they deleated the snotty nose post just as i was going to comment on it. You cant say anything in these forums. Just deleate everything and pretend it goes away when it just angers the customers more.
How comes they deleated the post but did not comment on if they were going to fix the typos? geeze.
Now i gota go find that guys name just to see if he got suspended again for complaining about being suspended lol.
You can say anything you like providing they don't break the forum rules. Some people forget that or think the rules don't apply to them.
Hi there
Resolution typo fixed. The stock we have should be DVI as it is what we ordered but I shall double check our stock.
There are 2 versions of this monitor iirc. One with vga only and one with dvi and vga. The dvi is more expensive than the vga only due to the tax overhead. Hope this helps.
Ah I remember this monitor now.
There was a large discusion and a lot of confusion around it on *****.
It was revealed that it only has VGA and it is TN panel.
I believe Acer do another monitor that is liek £100 more and that does have DVI and VGA.
Tbh I dunno whether its just me but I can't tell the difference in quality between VGA and DVI anyway.
