PS3 wireless keyboards
Caporegime
18 Oct 2002
West Yorks
quite fancying a wireless keyboard for using the web browser with the PS3
can anybody recommend one that works ? and do the trackpad ones work ? or do you need a separate mouse ? (do mice even work ? )
As far as I know any standerd wireless keyboard that uses a usb adapter should work, when I had my PS3 I was temped to get this,
Keysonic RF Wireless Keyboard w/ trackpad
• Wireless mini-keyboard with built-in touchpad and 2 mouse-analogous function keys
• Powerful and reliable radio-frequency transmission at 2.4 GHz
• Enjoy free and independent choice of site up to approx. 10 m away from the PC when operating this keyboard!
• Extremely flat construction with built-in hand cushion for non-fatiguing work
• Full functionality of a standard layout keyboard due to built-in numeric keypad and 12 function keys
• Extremely silent stroke and tactile feedback due to high-quality “X-Type” membrane technology
• Hot Swap and “Plug & Play” installation without special driver
• Ideal use for: home theater, conference and presentation facilities and mobile applications, as well as for modern office environments.
Hey.
i use the logitech dinovo set and it works fine (both Keyboard and mouse) just need to add them as any other bluetooth item
There's a Logitech Bluetooth keyboard especially for PS3 being released in Nov.
http://kotaku.com/gaming/keyboard/logitech-releases-ps3-bluetooth-goodness-299095.php
Not sure if it will be released in Europe as well as the states but I bet you coul dget one imported ;)
I cannot recommend this one highly enough. Works out of the box on PS3, Windows PC and my mac.
Very lightweight.
for £25 delivered you won't get a better all in one device. This device means I retired my MS wireless set, which has the big fugly transmitter on it, and also the RF reception on this seems better than the MS ones.
rp2000
EDit: I have not tried the mouse function on the PS3 (ie in the web browser. I will try this tonight).
Very lightweight.
rp2000
is it bluetooth or do you need to plug in a receiver ?
