Hi guys and girls!
I'm quite new to the overclockers forum, and was wondering if some of you nice people could help me!
Im after a freeview hard drive and DVD recording unit. I previously owned an old digifusion unit which has dual tuner and records just onto a harddrive, the idea was brilliant - look at the tv guide and click record on the programs you want, its exactly what i wanted (However it never worked, the stupid unreliable thing!!!), nice and easy plug and play so my dad can use it without having a haemorrage trying to work out what to do - he's technology illiterate basically, even though he owns a fair few gadgets! He usually just shouts to me to sort it out, so i need something thats very easy to use, nice and user friendly
So basically im looking for a decent recorder which will do this job. I dont need massive amounts of space, 160GB is more than sufficient, the dual tuner is deffinately an idea that i like so that i can watch one program and record another! However i already have an inbuilt freeview tuner on the tv so im guessing i wouldnt really need this feature.
My budget is around £250, i dont really want to go over this, but if needs be i will, but only just! Its doesnt need to be HD or anything as i cant see me upgrading my TV any time soon!
Cheers for any responses!
Jamie
. So basically im looking for a decent recorder which will do this job. I dont need massive amounts of space, 160GB is more than sufficient, the dual tuner is deffinately an idea that i like so that i can watch one program and record another! However i already have an inbuilt freeview tuner on the tv so im guessing i wouldnt really need this feature.
Jamie
, if it has then haing only one in the recorder isnt really that much of an issue, its a handy feature all the same.
