My gf is going travelling end of the year so I've made her a travel blog as a lil surprise before she goes away.
www.kimmystravels.co.uk
Firstly can you just critique it, any improvements etc.
Secondly I have a problem with both IE6 and 7. The nav bar (red bit under "Kimmy's Travel Blog") doesn't show initially, if you refresh or ctrl+refresh it still doesn't show, but if you click "Kimmy's Travel Blog" twice, which takes you back to the homepage the nav bar appears.
The source still shows the div exists and so does the IE dev toolbar, it doesn't show.
It's hard to describe but have a play in IE and you will see.
Any ideas?
Any ideas?
