In a bit of a fix...
24 Feb 2004
Leeds/Cyprus
OK, I've blocked the toilet, and we don't own a plunger. I could go buy one, but I'm kinda pressed for time here, need to unblock it fairly quick.
Give it to me straight: have we reached the necessity for hands here? I'd only do it as a last resort... Is this it? Has the moment arrived?
(braces himself for the inevitably "this thread fails", "TTIUWP" and "lol you idiot" replies)
any stick, even a a branch will do. it just needs ot be a able to bend
are you saying you cant go to the shops?
if you can find some electrtical cable, that would be good, as its reasonably stiff yuet bendy
/Groundskeeper Willie "Come here ya slippery bugger. Ah!, you've got yeself a wee friend have ya..."
Try the bucket of water suggestion first, that tends to work. If it doesn't, at this point I think you're going to be on your knees, elbow deep I'm afraid.
lol
Try the bucket method, use hot water, the hotter the better - I usually stick a kettle full of boiling water in the bucket as well.
I was in more of a hurry than I even knew, she walked in through the door a minute ago!!! :eek: Fortunately I had just disposed of the evidence with mere fractions of a second to spare. I used bleach, in the end. I didn't have time to check here for replies. I knew about the bucket, but I don't have one, unfortunately, and no time to go buy one. I didn't know about the baking powder and vinegar, might try those if it happens again! :p
Anyway, must dash off! Thanks for replies, request thread be closed and archived as it adds immeasurably to the store of human knowledge!:D
if you're sure its a u ben blockage then get your hand/stick/anything else in there and remove it! If it's further on you need some rods and to find the nearest manhole!
