As a comparison, I have downclocked my 1gb XT to the 1gb pro speeds and ran a few benchies :
3D Mark 06 Defaults:
XT11400 +- a little
Pro10000 +- a little
Difference-13%
X3 Reunion Bench 1920x1200 4AA (+narrow tent) 16AF:
XT58
Pro39.6
Difference-32%
F.E.A.R 1920x1200 4AA (+narrow tent) 16AF:
XT45
Pro38
Difference-15%
IL2 1920x1200 4AA (+narrow tent) App Pref AF:
XT60
Pro53
Difference-13%
So it would generally appear to be around 14% slower (Not sure why X3 was so much lower than the rest), for around 33% cheaper, good VFM at stock, great if it OC's to XT
Even the worst case of the test above still puts it even bang for buck.
Now if only they could fix the XP driver issues in 2D, and BSOD in GTL/GTR2 replays in XP ....
would anyone buying this card use 1920x1200 res ?
could you run them at 1680x1050
Can someone with a 2900XT 512MB (yes XT) please declock it to 600Mhz core and 800Mhz Memory (GDDR3 not 4), and benchmark it please so we can get a rough idea of how the pro will perform?
Thanks,
Matthew
I am currently looking at a card upgrade from my current x1950xt
To start with i was thinking of going for the 880 gts 640 mb card , but now i see so much hype and hopeabout the 2900 pro i am wondering if the 880 gts ( 640 mb ) card will actually be much better than the 2900 pro is hoped to be , and would the xtra money for the 880 gts be money well spent ? or a waste ? .
Wait it out. In about 3-4 weeks time it should be slightly cheaper and the reviews and threads will be flowing about the 2900 pro's. By then you will have a much clearer picture to help you decide.
but other places sells it too and cheaper.Was thinking that as well , but also thinking that knowing my luck by the time that happens and i order one they will all be sold out![]()
lol
Would a 475W Enermax Noisetaker be able to handle this card?
Currently have an X1800XT, 3800+ X2, 1.5GB PC3200 and 2 PATA HDDs working fine, so just replacing the X1800XT
but other places sells it too and cheaper.![]()
