Are there offline bots to practice with ?
Its out tonight over here so may have to go check it out - although my 360 is English so an American copy would not work right ?![]()
It would be VERY difficult for Bungie to make good bots since in Halo you are always jumping around and your feet arent fixed to the floor like most other FPS. The maps arent designed for them either with gaps to jump across so they would be next to useless.
Counter strike bots used to be able to handle that but they wouldnt randomly jump when they entered combat, i suppose it would be possible to implement as they could do everything else
that was awesome
its going to be sacriledge if the halo movie doesn't happen.
The movies a cert to happen. I think it was Peter Jackson that said when the movie companies see the halo 3 hype and how much it sells they'll practically be falling over themselves to get the movie started.
Are you referring to Halo, H2 or H3? I would agree if it was H2 and 3 however I think the original was mainly for splitscreen 4 players max unless there were lan parties going on.
