Hiper PSUs
5 Dec 2004
Hi Guys,
I will be building a PC with some althon 64 bits in it. The PSU I was planning on using is a Hiper PSU, now reading about the problems with them randomly blowing up makes me wonder if I should buy a better PSU, thoughts?
Cheers
Personally I wouldnt buy another Hiper PSU. Well not after it died taking the whole upstairs power out!
Corsair range gets my vote.
The main problem with Hipers has been the modular 580w versions (Type-R), partly because they have been significantly the best sellers in the range any problems with them will be highlighted but also once a reputation has been gained or lost it can tend to stick.
What PSU do you have?
I would definately buy a decent psu. It's not scaremongering with the Hiper's, it's a genuine problem. Just do a search for failed/exploding Hipers and you will see. Some of us are losing other components due to Hiper's blowing up. It's simply not worth the risk.
if you do want a hiper stay away from a 580w one. the other ones though, 530, 480w ones have not had complaints with.
and the 670w and higher ones i don;t know if anyone has bought one of those.
I had a Hiper 580R for just one day before it began to sound like a demented frog. Based on my own experience and that of many users of this PSU on these and other threads I believe that Hiper PSUs to be of inferior build quality.
My hunch is that Hiper's strongest feature is it's shiny finish.
