best case for a pa120.2
Yep I do, here's a pic
Thermaltake armour, the rad bolts in at the front using the holes for drive bay accesories, and it all fits in even with the thick rad and a push/pull fan setup.
I'll have one next week.
Planning on mounting it on the back of my Eclipse.
But I may mount it in the roof.
Will eyeball it up when it gets here.
I want mine internal.. but can't be bothered cutting - eclipse is a nice case though..
on a side note I used to love Pink Floyd.. takes me back to crazy days smoking with my mates in my youth.
*Feels Loved*
:D
I'm likely to be cutting a vent in the top of my case anyway next week, so changing to mounting a rad there isn't too much extra.
*Feels Loved*
:D
cool. post some pics when done.. with regards to thermaltake junior... it looks the same setup but with a few less drive bays.. how many bays in total does the pa120.2 take up in your armour?
ok the junior is in no way as versatile as the armour, but the armour is too deep for me.. is there any case that has a depth similar to armour junior but with the versatility of the armour..?
I am about to mount one in a NZXT Lexa case, internal top mount!
I had a NexXxos 120.2 in before but I want better cooling so will be shoe horning a PA120.2 in! It will have to line up flush with the DVD an will cut the bay shrouds to fit round it, but it does mean I will be able to bleed it easy!
Going to post pics when its all mounted an fitted.
Built a rig in an A16 earlier, could easily take a 120.2.
Was a pain to build in though, motherboard screw mounts were not pre-threaded.
Loads of effort to put in to get it right only to thread a few screws in the progress. Was very disapointed bear in mind its a £100 Lian Li.
Fitted my PA120.2 on the back of my Eclipse earlier (yes I've been busy today!)
Was pretty easy to fit with a swiftech rad mount. Pics coming later.
Lian Li V1200 takes a PA120.2 in the roof and it doesn't cross over the motherboard. Mekrel built one, unfortunately all the pictures have been removed from the place that was hosting them.
Yep I've got the same setup in my V2000 which as far as I'm aware is the same depth.
If you get it as far forward as possible, you can just squeeze in an 8800 GTX as well if you're running SLI.
Jokester
