25 Sep 2007 at 19:46 #1 marl marl Soldato Joined 16 Jun 2004 Posts 2,825 Hi, mate has pc which won't access internet. Error message come up saying that winsock - i think - needs reset. Anyone know what this is?
25 Sep 2007 at 19:50 #2 rpstewart rpstewart Man of Honour Joined 11 Mar 2003 Posts 10,704 Location Greenock, Scotland Winsock?? I haven't heard that mentioned in years... It's the Windows Sockets stuff, runs all the TCP/IP comms.
25 Sep 2007 at 19:53 #3 Carling Carling Permabanned Joined 22 Jul 2007 Posts 256 Its still in there... google "winsock fix" and you will get a little app that resets all the reg entries.
25 Sep 2007 at 19:57 #4 marl marl Soldato OP Joined 16 Jun 2004 Posts 2,825 Thanks, would a problem with this prevent a modem connected by an ethernet cable accessing the internet?
25 Sep 2007 at 20:11 #5 allllec allllec Soldato Joined 5 Aug 2006 Posts 4,261 Possibly, if its the most common form of the error then yeah i believe it does. as said above google 'winsock fix' very common problem
25 Sep 2007 at 20:14 #6 marl marl Soldato OP Joined 16 Jun 2004 Posts 2,825 Cheers guys, you've been a big help. I just googled winsock fix and am hopeful it'll work!
25 Sep 2007 at 20:57 #7 Tom84 Tom84 Soldato Joined 22 Sep 2006 Posts 16,080 Location Chelmsford, Essex rpstewart said: Winsock?? I haven't heard that mentioned in years... It's the Windows Sockets stuff, runs all the TCP/IP comms. Click to expand... Superb little program, got me out of loads of problems in the past
25 Sep 2007 at 21:02 #8 marl marl Soldato OP Joined 16 Jun 2004 Posts 2,825 Tom84 said: Superb little program, got me out of loads of problems in the past Click to expand... Good good good. I just downloaded it and i'll give it a go tomorrow.
25 Sep 2007 at 21:14 #9 markyb markyb Soldato Joined 28 Oct 2002 Posts 3,267 Location Essex Tom84 said: Superb little program, got me out of loads of problems in the past Click to expand... Yup same here. Can be handy for corrupted TCP/IP settings. Dont use it much these days tho.
