Its odd that the two power connectors are still there. I thought you could have gotten away with one.
Nothing lol, I'm just saying I dont think what he said is correct, GTS overclocked aint way ahead of a 2900 overclocked for sure.
.looks like ati will never get the hang of opengl. thankfully not many games come out using opengl.
according to the chart posted above they are same as the XT on noise.
Id go for the GTS if its going in a SFF, the 2900 will fry in a small case the amount of heat it gives out.![]()
"With the TES 1326 Infrared Thermometer literally in hand we found ourselves getting real-world temperatures from the products we test at load (3D clock speeds).
There are two places we pull temperature from - the back of the card directly behind the core and if the card is dual slot and has an exhaust point we also pull a temperate from there, as seen in the picture."
