Media Player Classic 6.4.9.1
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Changes in Media Player Classic 6.4.9.1 :
• Applied patches:
- ffdshow queue support (1015/1222)
- removed subtitle db stuff
- Disable monitor powersaving during playback on Windows Vista
• Changed some default settings:
- use Overlay Mixer renderer
- enable VMR9 mixer mode
- no rewind when done
- no looping
- enable exit fullscreen at end of playback
- disable file history
- disable autoloading of subs
- disable internal AVI/Matroska/MPEG/MP4/OGG source filters
- disable internal AAC/AC3/DTS/LPCM/Vorbis/MPEG2 transform filters
- use RealMedia framework for all RealMedia files (except .rmvb)
- disable WM ASF reader
• Other changes:
- auto-load subtitles option now also applies to embedded subs
- added the following extensions to formats list: .divx .hdmov .rmm .rnx
- added two shaders: Levels (16-235 -> 0-255) and nightvision effect
- Better looking icon
- Incremented some version numbers
Changes in Media Player Classic - Home Cinema 1.0.10.0 :
• New features :
- Latests Clsid patches (Bento4 0.9.3, faad2 2.6b, dtsdec 0.0.2, libmad 0.15.1b, libpng 1.2.18, zlib 1.2.3, mpeg decoder: progressive frames fix, mpeg decoder: dsutil interlaced fix v2)
- Command line "/d3dfs" to start MPC in D3D fullscreen mode
- Logitech lcd support (e.g. G15 keyboard)
- Remember file position and DVD position work only when "Keep history" is set (preserve privacy issue)
- Screen saver is now kick only when a video is playing
- Build for X64 plateforms (see detail above)
- Multilangual support : english, french and german. Need to download language pack and put Dll in MPC folder. If you want to translate in another language you can send me a private mail here
- DirectX SDK updated to August 2007 (v35)
• Bugs fixed :
- Wrong aspect ration with EVR custom (definitely i hope :-)
- Internal Mpeg2 decoder was not working with Evr and Evr custom
- Fix for problems with audio sync with Blu-Ray/HD DVD DTS files and wrong - AvgTimePerFrame calculation for DTS and AC3 (madshi)
OSD was not working when D3DX9_... dll was not present (display random pixels above video)
- Mouse is working in DVD menu with EVR custom on Vista
- Fix in FLV splitter when video does not start with keyframe
- Vulnerability CAL-20070912-1 in AVI source filter (could potential execute arbitrary code with the user's privileges)
- Vulnerability in FLI internal source filter (referenced by Team 509)
Download
Not tried MPC: Cinema yet, reckon it's worth it? I have WinDVD installed and the only diff over MPC I can see if native DVD decoding without the need for a system decoder for AC3 and DVD/HDDVD/BD videos?
"HC" has support for EVR.
Just been toying around with it and indeed been using EVR to watch a few videos, seems very good and I've also not noticed any clicks or pops that I sometime used to get on my XFI !
I might even uninstall WinDVD if this proves good!
agree that its better than vlc, never did like vlc as it didn't seem to get on well with my system. mpc was fine and always played the files that wouldn't work in wmp or qt.
