Satine (Senior Community Liaison Manager @ Codemasters Forums) said:
Hi all,
Please take into account the following known issues that are present in the PC version of the demo:
1 - Problems with ATI drivers causing corruption when Advanced Smoothing is enabled.
This manifests itself as:
a) black checkerboard-type squares across the screen, OR
b) all of the foreground areas will vanish to leave only some of the background visible, OR
c) the screen will appear extremely bright.
This issue is caused by the Catalyst Control Center attempting to override the game's graphics settings. To solve this issue open the Catalyst Control Center and
a) Set all hardware features to "Use Application Settings" in the Catalyst Control Center
b) Disable Catalyst AI
c) Disable "Adaptive Anti-Aliasing"
2 - Initial extraction utility isn't localised.
Whilst there are no workarounds, this does not affect the actual installer, which is fully localised.
