Hi Chaosophy,
i'm in the same boat as you, im gonna have to install mine under the card as my Zalman Flower is in the way. Just a quick ques, which direction did you have the fan blowing in your pic? Down towards the bottom of your case or up towards the card?
I've tried both, haven't had time to properly test but to be honest didn't see a huge difference in card temps either way. But a real test may show a difference once the case heats up.
The hardest part is fitting the cooler, ok you need to remove the card to easily flip the fan but once the heat sink is fitted it's no big deal.
Blowing up is the way I have it at the moment. That's part of the reason why I have removed the PCI blanking plates so that the fan has a chance to try and pull in some cooler air to blow up over the fins. And then for the hot air to be able to get out easier. Think I may stick one back in to get the air to flow under and over it(?)
Problem is that I'm a bit worried that heat is getting blow straight back on to the GPU chip and getting stuck under the card. Sticking my fingers in the gap does feel a bit warmer when this way. Though you do already have the vents in the 2nd PCI slot the card takes up for ventilation. Plus I have an Akasa Eclipse which is wider than a normal case, so a good few inches clearance at the side.
Still wondering whether a stronger fan would be better as I can't feel a huge amount of air flow making it through the fins, though the rizla test shows there is some there.
Blowing down, and the gap between the card and cooler did feel like there was less heat there but then all the heat was getting blow straight on to the back of my X-Fi. And with not a great amount of airflow front to back from the front HDD fan, the heat is just going to rise anyway.
re: air over the ram sinks. Which ever way you fit the cooler one lot of ram on the other side isn't getting any air flow. Plus when you remove the stock cooler the coper block is only cooling the GPU, and is the only bit getting air from the fan. Unless you're going for insane overclocks the ram sinks with little or no air flow should be enough. And if you are going for insane clocks you'll probably be on water and will either have an all in one block or ram sinks and no fan.
Either way I'm happy with the purchase. Other than this issue with the VDDC bit it's cooler and quieter and as yet I don't miss the missing slots. Thinking about seeing if I can flip the cpu cooler 90 degrees, fit the HR-03 the other way and have the whole lot blow up and use the PSU to vent, plus keep the rear case fan. But don't want to overheat the PSU and have it's fan start making all the noise.
Tempted to get a quad core if Crysis shows it's multi core potential, hopefully the demo will be fully multi core optimised and I can decide whether or not to go quad before next year. So may wait until then to flip the CPU cooler.
  Im def not paying more postage for them to not deliver it again.
