OCZ, GeIL and Crucial Higher Performance Memory Bargains!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Two amazing deals here for you guys:-
OCZ 2GB (2 x 1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
OCZ PC2-6400 Platinum Revision 2 is the latest version of the Platinum DDR2-800 Series. The PC2-6400 Platinum Rev. 2 has been re-engineered to turn out heart-pounding 4-4-4 timings with flawless performance and stability and offer lower latencies than standard 800MHz DDR2 memory.
OCZ exclusively developed these modules for the extreme gamer and overclocker to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and enthusiasts.
The new OCZ PC2-6400 Platinum Rev. 2 utilizes the latest OCZ heatspreader design. XTC (Xtreme Thermal Convection) Heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of the award winning OCZ Platinum DDR2 series, the PC2-6400 Platinum Rev. 2 is built with leading edge technology designed and qualified with special selection of premium components to maximize performance in even the most demanding computing environments. OCZ PC2-6400 products are 100% hand-tested to ensure compliance with stringent quality standards. In addition, each member of the OCZ Platinum family is backed by an industry-leading lifetime warranty, toll-free technical support and the exclusive EVP (Extended Voltage Protection) coverage.
With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum Revision 2 edition is a perfect memory upgrade for the latest CPU arrivials.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- OCZ Lifetime Warranty
- 1.9-2.0 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
Price: £36.99+VAT (£43.46 inc VAT)
BUY NOW!!
GeIL 2GB (2x1GB) PC6400C4 800MHz Black Dragon DDR2 Dual Channel Kit (GB22GB6400C4DC)
GeIL is reviving the famous Dragon Series in DDR2 form, named the “Black Dragon Series”. Solely dedicated to high performance graphics and gaming. Extra stability and durability with low power consumption. Frequency starts from 667MHz while maintaining CAS Latency to a minimal level. Behold, for the return of the dragon! The ever growing gaming market, or “eSports” as some might call it, is generating over 35 billion USD per year. This enormous group of gamers around the globe is creating such demand for specialized hardware to improve their in-game experience. For two years now, GeIL has actively participated in gaming communities, gaming events, supporting of professional gaming team, and now GeIL is proud to announce a new Gaming Series DDR2 memory line that is customized to fulfill gamers’ need of high capacity, performance & stability. Proudly introduce to you the Black Dragon Series with the maximum capacity of 8GB of memory packaged in the worlds’ first Quad Channel format. Speed is clocked at DDR2 667 and 800 where CAS Latency is clocked at 4 and 5.
- PC6400 800MHz CAS 4-4-4-12
- 64x8 DDR2 BGA Chips
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Red LED Light x 2
- 8 Layers Ultra Low Noises Shielded PCB
- Lifetime Warranty
- 1.9V-2.0V Power Supply
Price: £41.99+VAT (£49.34 inc VAT)
BUY NOW!!
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit (BL2KIT12864AA1065)
The Ballistix line is specifically built for performance enthusiasts who want to push the performance envelope without worrying about data loss or corruption, mysterious intermittent errors and display problems, or worse — the dreaded BSOD! The Ballistix line of high-performance memory modules features advanced speed grades, low latencies, and integrated aluminum heat spreaders.
- Module Size: 2GB kit (1GBx2)
- Package: 240-pin DIMM
- Feature: DDR2 PC2-8500
- DIMM Type: UNBUFFERED
- Speed: DDR2-1066
- Voltage: 2.2V
- Memory Timings: CL=5
- Warranty: Lifetime
- For warranty support and RMA replacement call Crucial Direct on 0800 013 0330 or 01355 586 100 who will replace your faulty memory within 48 hours.
Price: £79.99+VAT (£93.99 inc VAT)
BUY NOW!!
I already have 2GB (2x1GB) CorsairTwinX XMS2,C4 DDR2.
Can I add the first lot of RAM to my system with ease? I have a Q6600 setup, overclocked to around 3.2.
Any ideas?
DAMNIT!!! i literally JUST recieved two packets of the EXACT SAME OCZ stuff from OcUK through the door from the Mr postman!
Why OcUK! Why couldn't you have done this on wednesday! ;)
