This thread is priceless.
The 2900 Pro is £50 cheaper, just as fast, and people are still recommending the 8800.
And "the GTS overclocks" isn't really valid, as you know the 2900 Pro overclocks as well right?
I think ATi could bundle gold bullion with their cards and people would still recommend the 8800s.
Not really. We all know that both cards overclock really well. I think the pro is a great card for the money. I also think the 8800 GTS is too and same can be said for both the GTX and the 2900 XT.
I know there are price differences but there are speed differences as well.
2900 pro at stock is slower than a 8800 640Mb GTS at stock : FACT
So priced right at £50 less.
2900 pro at xt speeds is slower than a 8800 640Mb GTS overclocked : FACT
So still worth the £50 difference
An overclocked 8800 GTS can almost match a 8800 GTX at stock.
Doesn't matter how you stack it up, they will always be faster but also more money.
Now if the pro at stock was the same speed as a 8800 640Mb GTS then we wouldn't be agruing. You would be mad to buy a 8800 instead of a pro.
SO if you can only afford a 2900 pro then get that card. It's great and good value for money.
If you can stretch another £50 then get the 8800 GTS 640Mb. The extra performance is worth the extra money.
Equally if you can stretch another £70 more than a 8800 GTS 640Mb, get the GTX.
Me, I was on a tight budget so a 8800 GTS 320Mb for £160 was all I could afford. If the 2900 pro had been out I would have bought that in preference to the 8800 320Mb.
