Hi all been a while since ive posted here.
Basically as the forum post says ive had 6 power supplies die on me in the past two years. This is becoming extremely annoying as I dont exactly buy cheap power supplies. Im talking about enermax galaxies and ocz powerstreams all over 700w. Ive had my plugs checked and im running a decent belkin 6 way surge protector but this never seems to help at all and I am constantly barraged with power supply failures or problems.
Could anyone have any idea what exactly could be causing these problems as I have no idea considering ive checked the plug on my wall and have a surge protector running.
Yesterday morning I noticed that there was a slight burning smell inside the tower which I could not figure out what from. All temperatures were ok and cables were fine. In the evening the pc was automatically restarting periodically without warning when put under a slight bit of strain. Now all of a sudden it seems to be running perfectly fine. Im totally confused atm
Im running on : -
Intel Core Duo E6600 LGA775 Conroe 2.40Ghz
Asus P5W DH Deluxe WiFi
G.Skill 2GB DDR2 HZ PC2-6400C4 (2x1GB) CAS4 Dual Channel Kit
Was previously on Enermax Infiniti 720W EIN720AWT ATX2.2 Modular SLI Compliant PSU
Now temporarily running on Atrix 500w Psu (which is also now giving problems)
Lian-Li PC V1100 PLUS Silver Aluminium Midi-Tower
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI
3x Seagate Barracuda 7200.10 320GB SATA-II 16MB Cache
Thanks in advance for any advice you can offer
Im running on : -
