SQL query - left outer join
8 Feb 2004
London
Hi,
I have a left outer join query that links two tables:
Table 1.
field_a char(10) <- primary key
field_b char(20)
Table 2.
field_c char(10) <- links to field_a in table 1
field_d datetime
There may be several records in table 2 for every record in table 1. field_c is not unique in table 2.
I want to join a left outer join from table 1 to table 2, but I only want to return the most recent value in table 2, i.e. the most recent datetime in field_d.
Any ideas on how to do this in a SQL query?
I'm not too familiar with the group by clause, but it's saying:
Column name 'field_d' is invalid in the ORDER BY clause because it is not contained in either an aggregate function or the GROUP BY clause.
Trouble is I don't want to group it by field_d - just but group_c as you suggested
Any ideas?
thanks
select field_a,field_b,(select max (field_d) from table2 where field_c = x.field_a)
from @table1 x left outer join table2 on field_a = field_c
group by field_a,field_b
works a treat :)
if you have query analyser from the old days of SQL Server 2000 paste in the following
declare @table1 table (field_a char(10),field_b char(20))
declare @table2 table (field_c char(10),field_d datetime)
insert into @table1
select 'arse','hello'
insert into @table1
select 'bum','goodbye'
insert into @table2
select 'arse','01/01/1900'
insert into @table2
select 'arse','01/01/1910'
insert into @table2
select 'bum','01/01/2010'
insert into @table2
select 'bum','01/01/2000'
select field_a,field_b,(select max (field_d) from @table2 where field_c = x.field_a) from @table1 x left outer join @table2 on field_a = field_c
Cheers guys - that's worked a treat.
My SQL trigger is now stupidly complex :D
(on the bad side - tricky to debug later. on the good side - job security :) )
the "a" word may be a naughty word, but nice to see others have similar test data to myself :p
HaHa, yeah I'm not the only one at work that does that either
If I'm testing something it's always been join/insert/group words like that :o :p
Others tend to use their names as variables or whatever... but if it's just testing and it's not going to make it into the main body of some code - who cares :D
I'm sure it would be possible to do it without a nested select query, it might be worth playing around :)
