All-in one "cheap" 5.1 setup, or high-end PC kit for home cinema?
Pug
Pug
20 Oct 2002
Over there...
got a small budget (like £150) for 5.1 setup.
The options i have are: low-end home cinema setup, with 5.1 and a DVD player (possibly without digital in for the 360) or a set of Logitech Z-5400s.
These are really PC speakers imo, but good PC speakers, and i can use the 360 to play DVDs. These have a better range of inputs too, tho truthfully i only really need inputs for the 360 (suppose i could pro-logic my Virgn cable).
Opinions?
I run the Z5450's or something like that in my sitting room, the ones with the wireless rears. Sound better than my Yamaha amp with Kef speakers did.
for that sort of price you're only option really is to go for a PC setup.
you just wont get anything better from a hifi setup for that money.
A decent set of PC speakers will be a hell of a lot better than most of the cheaper all-in-one setups. A few of my mates have some and while they are ok, they are no match for even my 5 year old Creative speaker set.
Would the Z-5400/5500s be any good to connect the following (at once):
1x phono to 3.5mm (MP3 player/laptop etc)
1x coax digital from DVD player to speakers
1x Wii phono (split off the component cable) to speakers
... And that's it, I think!
They have connections for, 1 coax, 2 optical and 1 set of 5.1 inputs which are split between 3 stereo headphone jack connectors. These can be split to form 3 seperate stereo inputs so in short yes.
you can get a full 5.1 setup from yamaha for around that budget and that includes a DTS amp!
this is a 6.1 setup for a little more, but the 5.1 setups are available for a little less. I paid around £170 for mine 2 years ago.
http://www.soundandvisiononline.co.uk/moreinfo/index.asp?product_id=13011
good spot. I did notice that myself too, which confused me a little...
not sure which way to go.
My mate has that setup, and tbh it sounds pretty good. And it has HDTV Component inputs, so i could use it as a switcher (tho this would be pretty pointless as only my 360 is component lol!) Uness there is a PS2 component cable?
it will be much better than any PC setup.....
it has all the inputs i would need for my PC setup anyway. I'm considering moving my Xbox360 up to the study soon aswell......
Guess you either have a very small sitting room, or there was something wrong with your Yamaha/Kef setup.
PC speakers are not very high quality, often designed for looks more than sound quality, and their 'spec' sheets are about as much use as school toilet paper.
When a PC speaker says '500W' it never backs it up, so its probably 500W 'DIN' at 50% distortion, with just the sub making any sounds. Real hi-fi gear is normal rated as watts RMS, 20-20000hz 0.1% (or lower) THD etc etc etc... If you took a proper piece of hifi, and allowed it to perform as badly as the PC speaker specs, a typical 100 watt hifi amp, probably kicks out a 1000W of logitech power :P
I wouldnt by an all in one setup too. Just like the PC speakers their specs are written to 'look good' in the shops, but in reality are completely meaningless. Better off looking at second had separates. Also be carefull with those amp+speaker packages as well. Sometimes they look good on paper, but have some problems when it comes to upgrade time.... Friend of mine has a sony one, and it's ok... Except there is no way to change the crossover frequency's. So when she tried to upgrade the front speakers (to make better music), there was no way to stop 90% of the bass being redirected to the sub :(, So the sound was hardly upgraded at all.
The logitech reviews at the time were very good indeed and many reviewers claimed they would put hi fi gear selling at a £1000 to shame funnily enough.
