Mines totally different, I cant get mine off!!!
Mines for a tomtom one...
Josh
It must depend on the window then?. Still not a good design I'll be picking up one of the twisties.
Josh
Did you know that Tom Tom have actually opted to use the same flower mount pictured above on their flagships models the Go 520 and 720. The above flower mount, if fitted correctly is capable of holding up 80Kgs of weight.
An alternative mount for your Tom Tom One V2 isn't available, your stuck (Pun!) with that one.
I can believe that, I dont think i can pull mine off without lifting the tap first.
So the general consensus is that for some they work great and others have mixed issues.
Id say so yes, can you not try yours in another car?
My uncle has the Go 520 and his comes with a flower twist mount![]()
The window is perfectly clean mate I gave it a clean the other day. TBH I'm not risking it again It's too much of a liability it seems
Josh
Plus, Im also curious why you always seem to make daft comment's in my threads, any reason?
Here is another example..
http://forums.overclockers.co.uk/showthread.php?t=17783328
Annoying little comment's which really don't help![]()
I didn't even make the connection that it was you both times
It wasn't a daft comment in either thread, the last one you said "Check my new ICE install" which is a commonly used phrase for an actual install - sub, speakers, screen, carputer, whatever...but not just a headunit...
Mine's fallen off before and I didn't even give it a second glance...perhaps you've just got a nervous disposition![]()
Last time I checked ICE meant In Car Entertainment. The headunit being a part of that I felt it was appropriate to use that title. Not my fault you seem to be anally retentive and nit picking (can't please all).
Ain't you just the hero. No when concentrating on other things like driving I don't need my TomTom come flying off my dash as I'm trying to concentrate on a busy road and various other things going on around me.
