Hello.
I'm gonna take the plunge at the end of the month (or wait for the 8800 GT in Nov) and upgrade my 7900GS to an 8800 GTS (or GT depending on the price).
Question is, is it worth paying the extra 30 or 40 quid for a factory overclocked card? the BFG is a fair amount more expensive than the EVGA. Cant i just clock it myself? But then surely they wouldn't bother clocking them if you could just do it yourself?
Confusion.
Thanks!
Confusion.
Thanks!
). Some will overclock better, some will run a bit cooler, some may use a bit less power etc. When you pay for a pre-overclocked card your just paying for a guaranteed better quality card really, but you can get lucky and buy a standard one that turns out to be as good.
